Help wiring (4Ω + 4Ω) sub to an Audison srx1
  • 4
Where it says speaker out...... Thatss where you connect it
in op's defense this amp is a little confusing with two completely different outputs // both giving output but with diff dampining factors
you can only use one set @ a time electronic or acoustic if u hook both up together amp goes pfft.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
613
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
975
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
rvd
rvd
calgary, ab
dappa5
    May 24, 2024
    May 23, 2024
