R rvd Junior Member 4 0 calgary, ab Feb 25, 2012 #1 Could I get help wiring a (4Ω + 4Ω) dual 4 ohm subwoofer to an audison srx1 mono amp. TIA. Click to read more...
Imtjnotu 5,000+ posts Me Gusta Edition 13,191 299 San Diego CA Feb 25, 2012 #2 Just connect the positives on the subs to the the positive on the amp and connect the negatives on the subs to the negative on the amp
CodyWayne718 10+ year member Senior VIP Member 168 1 Kentucky Feb 25, 2012 #3 Depends on what load ya want Car Alarm, Car Stereo, Mobile Video, and Cruise Control Info for Installers ---------- Post added at 08:14 PM ---------- Previous post was at 08:13 PM ---------- Subwoofer Wiring Diagrams
OP R rvd Junior Member 4 0 calgary, ab Feb 25, 2012 Thread Starter #4 Let me be more specific, where do the speaker wires from the subwoofer, go on this amp ?
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Feb 25, 2012 #5 http://www.audison.it/content/eng_srx1manuale.pdf use the electronic bass outputs both on that side // do not use the acustic bass side hook up both coils (either @ woofer {+2+ and -2-} or just run a wire from each coil to amp )
Imtjnotu 5,000+ posts Me Gusta Edition 13,191 299 San Diego CA Feb 25, 2012 #6 Where it says speaker out...... Thatss where you connect it
dappa5 10+ year member DO WORK! (if u can) 1,858 0 S.W.FL Feb 25, 2012 #7 Where it says speaker out...... Thatss where you connect it Click to expand... in op's defense this amp is a little confusing with two completely different outputs // both giving output but with diff dampining factors you can only use one set @ a time electronic or acoustic if u hook both up together amp goes pfft.
