Help Wiring 2 Kicker CVX d2
wptightend
Hi I have 2 kicker cvx dual voice coil 2 ohm subs. I was running them off a mono am a zx1000.1 and wired it wrong and blew one of the subs. My question is Ive looked at all these diagrams on how to wiring them. Ive looked at wiring just one and wiring 2. Im confused on wiring voice coil 1 and 2 + and -. If someone could help me out and explain it to me, ive looked at all the diagrams in the world. But if someone with the experience of doing it themselves could help me it would be very very much appreciated thanks.
jake
wire 1 sub that is dual 2 ohm-
run positive to positive, negative to negative, now run the main positive and negative to amp for a 1 ohm load
wire 2 subs this is dual 2 ohm-
Final load is 2 ohm-
for each sub- run positive on one side to the NEGATIVE of the other side. Do this to both subs.
Now take the positive of the remaining side of sub A and run it to the remaining positive of sub B. Do this also with the negatives running remaining negative terminal from Sub A to remaining negative terminal to sub B.
Now run the main positive and negative terminals that you just spliced together to amp.
wptightend
wptightend
Occoe FL
Got_Bass89
Mike Mccabe
