Help Tuning XX-Hercules
Supergumby5000
Project: F350 begins...
Well, i dont know much about all of the options on this amp heh. Thought i would go ahead and ask and get to know what i can before i just start spinning the knobs and seeing what happens.
Anyways, heres whats there:
Impedance (47k - 0.6k)
Level (9v - 0.2v)
Subsonic (10hz - 50hz)
Low Pass (35hz - 250hz)
Bass Boost (0db - 18db)
Bass EQ (30hz - 60hz)
Q Control (wide - narrow)
Phase Shift (0 - 180 degrees)
If anyone could point me in the direction to figure all of these out, or help me with some info, that would rock...
Level (9v - 0.2v)
Impedance, don't know what the hell that did
Level, Set with a multimeter
Subsonic, around 20-25
Low Pass, 80-100
Bass Boost, 0 if possible
Bass EQ, around your peak freq if you use bass boost
Q control, dont know what the hell that did
Phase Shift, 0 unless you invert the sub
Impedance, don't know what the hell that didLevel, Set with a multimeter
Low Pass, 80-100
TTT
still need to figure out what to do with Impedance and Q Control, or at least know what each of them actually are/do hehe. And One Bad MOFO, if im not using my bass knob, does it make a different for the Bass EQ? how do i figure out what my peak frequency is? Should i just play with it and see what sounds good?
Supergumby5000
Supergumby5000
Pullman, WA
Supergumby5000
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
