help to wire my system
jojo1212
sup guys ?
so my system is ready
got 2 amps
1- rockford P600.1bd
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6&family_id=19&item_id=106477&locale=en_US&p_status=
2- rockford punch45
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=8&family_id=26&item_id=100035&locale=en_US
rockford T162s component speaker for the front
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=3&series_id=34&family_id=29&item_id=91973&locale=en_US&p_status=
rockford P1692S component speakers for rear fill
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=3&series_id=33&family_id=28&item_id=91967&locale=en_US&p_status=
2 JBL GTO 1204D subwoofers
http://www.jbl.com/car/products/product_detail.aspx?prod=GTO1204D&Language=ENG&Country=US&Region=USA&cat=SUB&ser=GTS
everything is installed
i just need you guys to advice me in wiring the speakers and the subs to the amps
best wiring options
thnx yall in advance
Rockfords website should have all the info you need as far as diagrams. If you need to know how/ where to run wires through the car, start reading as there is lots of info here. You subs are dual voice coil so you should hook them up for a 2 ohm load to your amp. If you have any doubts, pay someone to do it for you. Thats all the help I can give, being a newbie my self. Good luck.
youd probably be better off to get it professionaly installed cuz if u mess up well your screwed, at least u can go back to the professional and get him to help out. hopefully you have a warranty if you do it yourself.
just a 2 guage for the amp and for the subs used a 8 guage wires....ground and power wires has the be same guages to be putting out enough and the same amount of powers so thats why use a bigger wire...2 guage is big enough...
ok thnx yall
my amps are already installed and wired
my question was to which amp i should connect the front speaker
to which amp the rear speakers
since i dont know alot about watts and wrms
i dont wanna connect some speakers to a powerful amp which could destroy them
for my subs i wannt to connect them to the p600.1bd amp
but rockford site states that the amp can push 600W x 1 @ 2-Ohms RMS
so will this jbl sub (only 300 rms) take that load of power when wired at 2ohm
and when both of the subs are wired like this to the amp
http://www.jbl.com/car/product_support/SubwooferWiring/sub_wiring_diagram.aspx?type=2-4-4
i still have one channel left on the amp, so can i use the other one for other subs
or speakers ??
i want the best wiring option for my subs
If you have two 4 ohm subs then you should wire them in parallel to present a 2 ohm load to the amp. That's probably how the amp is wired internally (that's why there are two positive and two negative terminals), but read the manual to find out for sure. If it isn't, you can read the manual to find out which one positive terminal and one negative terminal you should use and just wire the subs in parallel before the amp.
You have a 2 channel amp for your front stage, so you can run the fronts (as long as you have passive crossovers) off of the amp and the rear fill off of the HU.
jojo1212
jojo1212
ummm
jojo1212
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
