Help T40001bd problem
i would completely disconnect the amp. then make about 1.5' power and ground wires.
run the power to a battery, the ground to the battery, and then use wire for the remote turn on and go straight to the battery positive. if it still goes into protect the amp is bad.
right now you're just looking, and pulling wires etc etc. i think the best way to check is to remove everything from the equation. no long runs of wire through the car, no power for the remote turn on from the hu, nothing. just straight to the battery. hell you dont even have to use big *** wires as you're not going to make any power, just test that the amp will turn on and work.
x2, easiest way to narrow down the possible problem.
Well the power and ground from amp to batt is literally a foot. And I have everything else disconnected and used a small wire from remote to + and still came on yellow. Please guys I need this thing fixed and running asap. Please let me know whats the best way to go about this. Thanks
Well if you tried every then there is obviously an internal problem. Send it to Amp Repair Center. They'll fix you up.
i tell u what, i'll buy it off u for 350 shipped.
j/k ( unelss u wanna sell it to me)
but on a serious note, i didn't see but did u try unpluggin the rca's and then powering it up?
i had this issue at first with my t3000.1bd but it was my ground.
Did you ever try running the remote wire just to the + on the battery? Last time something had cut my remote wire, and it had shorten the wire causing my 4 channel RF amp to go into protect. I had figured out that it was the remote wire, and i had replaced it with another one and everything worked fine again.
bumpin buick
Science is everything
bumpin buick
Appleton, Wisconsin
bumpin buick
