Help T40001bd problem
bumpin buick
Science is everything
I have spent all week on this install get everything just the way I want it. Well I am heading back to school tommorrow morning and I really want this thing working.
When I turned the car one the car immediatly goes into protect.
Heres the situation I have the T40001bd hooked up to 5 batteries.
I grounded the batteries with 4/0 awg and have the amp grounded to the batts. I put the DMM on and was getting 13.5v at idle so that shouldnt be an issue. I'm hoping this isnt an issue with the amp because as far as I could see everything with it was fine. Im guessing its either a ground or remote but I know I have that hooked up right. Let me know what you guys think, thanks much.
Unplug the dedicated remote wire, find a piece of short wire, connect the wire from the remote terminal and the positive terminal and see if the amp works.. it's just a small step in the process of elimination.
Edit: I don't know then bud.
It starts the amp and the amp goes right into protect
did you try unplugging your rca's and turning the car on?
changes nothing
The only other thing I can think of is bad ground.. but you said it was good.. //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif If it were me, I would open it up and check the board for anything out of the ordinary.
bumpin buick
bumpin buick
Appleton, Wisconsin
bumpin buick
