HELP! System won't turn on??
hotrodkid
Ok so i got a simple system from my buddy. Its a MDS 1200 watt amp, and a 10" Infinity sub. I hooked my wires up to the deck, and my power and ground cables up. Then i hooked my sub to the amp, but nothing! My amp doesnt even look to be on! The led does'nt come on to signal its getting power. Could the amp be blown?
By "fuse good", which fuse do you mean? The one in your power cable or the fuse(s) on the amp?
...maybe bad ground?
take a smidge of wire and run it from your power to remote wire. If it turns on, its your remote wire.
When you tested with the meter, what two points did you test, and what did the meter read?
hotrodkid
hotrodkid
ohuston
blackbonnie
BP1Fanatic
BP1Fanatic
