pro-rabbit
Moderator
I don't think there is an issue at all. I personally think you had the settings far to high and the shop turned them down.So u think there is a problem I have a mono block with two terminals I had each sub wired in series goin to there own terminal and it sound deep and hit hard
Your amp may have two terminals, but it is actually only one. It has two for making wiring easier.
If you think the wiring is not right, then pull each sub and verify how it is wired. Then check the wiring from the box to the amp.
