Help subs not pounding
So u think there is a problem I have a mono block with two terminals I had each sub wired in series goin to there own terminal and it sound deep and hit hard
I don't think there is an issue at all. I personally think you had the settings far to high and the shop turned them down.
Your amp may have two terminals, but it is actually only one. It has two for making wiring easier.
If you think the wiring is not right, then pull each sub and verify how it is wired. Then check the wiring from the box to the amp.
I required them to series parallel this mornin and then the shop tuned them so I'm guessin they playin it safe but I can't go over 35 on my head unit cuz that where they maxxed my tuning
See that the thing I'm new to this and idk if the amp to high or wat I have a crunch 2000 watt 2050.1 amp to those subs amp is set at 2.25 voltage and barely any gain like the shop left it and they don't bump what should I do
---------- Post added at 11:07 PM ---------- Previous post was at 11:07 PM ----------
It's the brand new amp by crunch powerone
I have owned this amp and made the same mistake man... THat amp puts out 500 watts at 2 ohms not 1000 like you would expect. To get anything out of it you have to wire to 1 ohm.
Warmachine9210
Warmachine9210
Topeka,ks
Warmachine9210
