help,sub thump everytime I change a track?
adammk5
theres a really low frequency thump everytime i change a track on my cd player, it's so powerful that it makes my sunroof hop about a centimeter.It gets really anoyying,I think it's my brutius amp i'm not sure.
my system sounds really good but my sub thumps between tracks
my sub is in a 3.5 cube sealed box(15xxx) with polyfill
i'll be standing by for a response,thank you
Upgrade you ground connections for your Headunit and Amplifier. Make sure they are tightly secured to bare metal with the same size wire as the positive power wire.
Also make sure you have run your RCA and speaker wires to the sub away from power and ground connections.
if these do not work try different rca's and if thats not it have the deck and the amps tested for a cold soldier joint in the rca inputs and outputs
dude bump, my friend has the same problem.
whenever he changes cd or turns the car off with the sub switch on, there's this loud ass freaking bass haha, scared me $hitless
458
Resonix is supposed to be the bees knees, but it is a little $$. If I was doing the whole car, probably would shell out for the entire resonix...
25
2400w x 4 peak and 120w rms x 4. That has to be world record dynamic right there 🤣.
28
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
adammk5
adammk5
Houston, TX
JL_W6_v1
maylar
    Jun 2, 2024
    Jun 1, 2024
