Help On Sub Wiring
I had it like that on my old Ultraliener amp though and it blew it. I hooked up the Lanzar like that last night, and it blew the fuses. So a friend wired it like this ---> http://img177.imageshack.us/my.php?image=53228489xk6.png and it dosent pound hard at all. I currently have it bridged and wired how my friends did it. So when i wire it like the image that n2audio posted, it will pound???
the image you posted is wired in series.....you would have an 8 ohm load per driver, then paralleled at the amp would be 4ohm load. That wouldn't be much power from the amp.
wired as n2 posted would present a 1ohm load to the amp and you would get more power.
I had it wired like n2 posted at first, and when i put power to the amp, the fuses in the amp blew instantly. Im just afraid they would blow again.
get all the settings correct on the amp and you shouldn't have any problems....what size power and ground are you running?
and make sure there is no arc across the terminals
SunfireGT
Law Enforcer
SunfireGT
Ft. Wayne, IN
Alex JB
