Help needed in sub setup
  • 2
Reggaeman
Hi there, Im about to try and set up a subwoofer in my car, I have the sub and also a choice of 2 mono block amplifiers to power it.
The Subs specs are:
10"
Nominal impedance 4+4 ohms(Dual Voice Coil)
Power Handling 700w
Maximum Allowable Power(according to manufacturer) 350w (Im not sure if this means rms?)
Amp number One Specs are:
Max Power 1000w
RMS Power Output 410rms - 1 channel @4 ohms
RMS Power Output 555rms - 1 channel @2ohms
(this one has a subsonic filter)
Amp number Two Specs are:
Max Power 800w
RMS Power Output 262rms - 1 channel @4 ohms
RMS Power Output 368rms - 1 channel @2ohms
This is the first time Ive wired up a dual voice coil driver and know there are several different ways to wire it to get different loads (parallel and series)
My question is which amp would I be better off using and what way should I wire the chosen one?
Thanks in advance to anyone who can take the time and point me in the right direction.
Mike
A lot of variables are missing to give you a solid recommendation. But, amp one at two ohms and adjust the gain accordingly.
Well it turns out both amps are dead in the water. so I am on the hunt for something that will match. I have attached pic of one of the only bits of info I can find on the driver. Its a
Fusion FPW-1000
So im trying to work out if its
DVC@ Ohm 4 + 4
Maximum allowable power (according to the manufacturer), W 350
Does this mean it is 350 rms per coil or in total @2 ohm or what?
Sorry if these are really simple questions it is just I really dont have a clue how to work out what im looking at
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
481
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
Thanks for this! Yes, there are 6.5 door speakers, front and back. I've heard them referred to as woofers but I'm sure their frequencies included...
Reggaeman
Reggaeman
Cork, Ireland
Reggaeman
    May 10, 2024
3toneEYZ
    May 10, 2024
