Help me with this wiring, confusing me
plyer3
I have 2 10" subs DVC 4ohm each. My sub box only has SVC. I had the subs installed into the box by someone and don't know how he wired it. I'm getting a new amp to power these 2 subs.
How should I wire the subs to the box? Looking at diagrams but the pictures had the subs directly wired to the amp and not the sub box to the amp. Should I use 4ohm or 2ohm? 600rms each sub. Should I get an amp for the 4ohm or ohm and would you recommend me mono or 2-channel amp?
i want to wire them so i can use it on an 1ohm amp 1200rms.
can you give me details on how to do that? something similar to one of those diagrams.
im a total noob at this.
I think this is what you mean, if not then i dont know
1 ohm ^
4 ohm ^
First sub ~
Take both positive inputs on the subwoofer and wire them together to the single positive post on the enclosure's terminal.
Do likewise for both negative inputs on the subwoofer to the negative post on the enclosure terminal.
Second subwoofer~
See above.
plyer3
plyer3
N Little Rock, AR
plyer3
