help me rebuild my front stage and integrate rear fill
Well I was thinking that since madisound usually models the drivers as well, and the xos are setup to work with 8 ohm tweets and 4 or 8 ohm mids. I could make sure I choose tthe drivers wwith correct nominal impedance and with an Fs out of the range it will be playing....still wont work?? I'm still learning here.
Fitting an 8 will do wonders.....awwwwww yyeeeeaaaahhhhhh kinda wonders. I don't know what it is about midbass 8s they just do it for me they bring the substage forward quite a bit and seem to balance out the highs better.
---------- Post added at 03:04 PM ---------- Previous post was at 03:03 PM ----------
I also agree where theres a will theres a way, may need to do some fiberglass work but be worth it.
I would never use that driver in a car. It is ment to be rear horn loaded, in a TL, or at least in a big ported box. And will most likely need to be on axis to sound good. plus they are $250 each!
Now you're getting somewhere. Yes you will need a tweeter with the scan speak driver. And a xo.
If you look at the impedance graph for that driver you can see that, although it is a 4 ohm driver, if you crossover at 3,000 Hz the impedance is about 8 ohms. This is one of the reasons passive xo's are hard to do. Oh and the impedance can change when you put it in a box!
Duane
Duane
would my door count as an impedance changing box? what about a lower xover point? but then that might require me to keep the mid and tweeter closer together...or maybe try a diff driver? What should I be looking for in a mid chart? flat impedance?
I was and still am a old school CD type of listener. Pio always had great CD players and fairly good TA/EQ options, got familiar and you know what...
49
175
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
531
375
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
364
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
Why So Cereal?
    May 16, 2024
    May 16, 2024
