Help me find a 4 channel amp that when bridged runs 2 ohm stable
* Power T15004 - 1500 watt 4-channel amplifier
* Download Owner's Manual
125x4 @ 4 ohms, 250x4 @ 2 ohms, 375x4 @ 1 ohm, 750x2 @ 2 ohms, variable 40-4kHz HP/LP selectable 12dB/oct Butterworth, 24dB/oct Linkwitz-Riley crossover, 10x crossover switch, 2/4 channel switch, 12dB/Octave Infrasonic filter @ 27 Hz, RCA inputs, independent RCA outputs with 12dB/Octave HP/AP/LP Butterworth crossover, cast aluminum heatsink, military spec PCB, 1/0 AWG power/ground connectors with built in ANL fusing, Intelligent thermal management, and variable 35-70Hz remote ParaPunch Bass EQ 0-18dB. H 2.6" x W 12.8" x L 33".
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
Dayton would be a really nice choice as well as the SQL. I would look at a R. Sounds sub too https://www.resilientsounds.com/product-page/gold-15...
For a sub that small.. Id like to see an 8 or 6.5 @ around 55-70 htz usually sound pretty nice and clean on approx 40-100 rms @ 4 ohms. 8 ohms I...
You have a lot of great points stated here. I like it.. Nothing wrong with a little head room on any amplifier to run at lower gain settings to...
20
190
dangerzone9k
dangerzone9k
D.C.
streetacrx
