help me choose between 2 brand of comp???
How about sticking with kicker......check out the kicker k693
Model K693
Woofer(IN., CM) 6 x 9, 15.3 x 22.9
Midrange(IN., CM) 2-1/2, 6.4
Tweeter(IN., CM) 1/2, 1.3
Impedance (OHMS) 4
Maximum Amplifier Power (WATTS PEAK) 180
Maximum Amplifier Power (WATTS RMS) 90
Sensitivity (dB 1W/1M) 92
Frequency Response (Hz) 30-21k
Mounting Hole Dia (IN., CM) 6 x 8-9/16, 15.1 x 21.7
Mounting Depth (IN., CM) 3-3/16, 8.08
Grills Yes
Just right for your 87 x 4 amp don't you think.
only $129 at onlinecarstereo.com
This would be a decent amplifier to run on what you have. I would spend a little more and get the 460.4 if you can swing the extra funds. Ive...
4
Sub should be in the cargo area for best results. I'm skeptical about those unknown brand Chinese head units myself and would stick to known...
I am upgrading standard door & dash speakers in a VW T5 camper (2005) using a plug and play upgrade bundle, continuing with the two-way setup...
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
116
blueski
blueski
NJ
blueski
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
