Help!! Just got subs installed and not bumping
Steingk1
I just got my subs installed
CVRDCVR12 2 12 inch kickers
Max amp 1600
Min amp 800
2,4 ohm
The amp I have is Boss Imp10002 1000w 2 Ch Car Audio Amplifier Amp 2 Channel 1000 Watt
And I have a pioneer radio. When I put on a song the subs bump for 30 seconds then go off and just my speakers are playing. Any ideas on what the problem is?
Thanks!
So i have 2 12 inch kicker cvr's in the box that came pre-wired at 2 ohms final impedance. there is only 1 positive/negative terminal on the box
Your amp is only stable bridged at 4 ohm. You're trying to run it at 2 ohm bridged and it's going into protect mode. You can get inside the box and wire the subs separately (which are dual 2 ohm) to each channel of your amp at 4 ohm. This will keep it from going into protect mode. My suggestion would be to sell the amp on Craigslist and get a monoblock that is stable to 2 ohm and does around 600-800 watts rms. There's some in the classifieds here that will do you just fine for 100-150 bucks. That Boss isn't going to show you any power either. To be honest, it's a piece of garbage.
Steingk1
Steingk1
Connecticut
brian84corvette
