Help!! Just got subs installed and not bumping
Steingk1
I just got my subs installed
CVRDCVR12 2 12 inch kickers
Max amp 1600
Min amp 800
2,4 ohm
The amp I have is Boss Imp10002 1000w 2 Ch Car Audio Amplifier Amp 2 Channel 1000 Watt
And I have a pioneer radio. When I put on a song the subs bump for 30 seconds then go off and just my speakers are playing. Any ideas on what the problem is?
Thanks!
Basic things to always check first is that you have a good ground. Metal on metal with a soild ring terminal. Then check how you have subs wired. You didn't say if you had 2 ohm or 4 ohm but I suggest looking up a wire diagram online somewhere like crutchfield. Finally, if all else fails, check your voltage at the amplifier. Your going to need a multimeter or something that can measure 12v DC. If everything is wired correctly than its probably your amp. Anything made by boss,pyle,lanzar,dual, or anything you can buy at walmart is probably a waste of money.
Steingk1
Steingk1
Connecticut
brian84corvette
