Help in wiring single sub to this amp!
Hcw
USX 2080 amp
Details:
•stereo or bridged mono output
•Tri-way capable (Tri-Way crossover required)
•140 watts x 2 at 2 ohms
•280 watts x 1 in bridged mode
•requires 10-gauge power and ground leads — wiring and hardware not included with amplifier
•variable high-pass (65-4500 Hz, 12 dB/octave) and low-pass (40-460 Hz, 24 dB/octave) crossovers
•anti-thump circuit
•speaker-level inputs
•preamp outputs
•thermal, short-circuit, and power/ground reversal protection
Single Sub. Polk 1040 dvc
•10" Polk Audio db Series Marine Certified Subwoofer
•Power Handling:
◦Peak: 540 watts
◦RMS: 270 watts
•Impedance: Dual 4 ohm
•Polypropylene cone
•Santoprene surround
•Fire-retardant flat NOMEX® Spider
•Double venting of the 4-layer Kapton Voice Coil Former, Cone/Coil Coupler and Pole Piece
•2" Kapton dual voice coil
•Frequency response: 28-200 Hz
•Sensitivity: 86 dB
Is this the correct way to wire this amp to the sub?
both + terminals on sub wired together than going to + positive terminal on channel 1 of amp
both - terminals on sub wired together than going to - negative terminal on channel 2 of amp.
This should give a 2ohm load and take advantage of the 270w from the amp to the single sub?
i am getting confused with the 4 0hm dvc if this takes it to 2ohm and the amp is also capable of this?
Thank you.
Is that an Acoustics USX 2080? If so I believe it is only 4ohms mono/bridged.I will look specs up if I can find,It could be 2ohms stable, but not likely if it is one im thinking of.
Only thing I found was ..It is a Zed Made amp, but ,bridged/mono, it stated @4ohms.Any lower, and you run a chance of cooking that amp.Thats of all I could find at the moment.
So I need to either replace with svc 4ohm sub to run off this amp or move it over to the rear 2 channels of my quart Q.4.150 that is 2 ohm stable and use this zed amp to run my front fos
gate 4 inch coaxials by the sounds of it? sound about right.
AMP Specs.
• Q Series 4-Channel Class AB Car Amplifier
• RMS Power Rating:
o 4 ohms: 150 watts x 4 chan.
o 2 ohms: 220 watts x 4 chan.
o Bridged, 4 ohms: 440 watts x 2 chan.
• Max power output: 1760 watts
• High Speed MOSFET Output Devices
• LED power (green) and protect (red) indicators
• Variable Bass Boost (0 to +12 dB bass boost from selectable frequency range 30-80 Hz)
• Soft Start Turn-on
• 4/3/2 channel operation
• Preamp RCA outputs to daisy chain multiple amps
• 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
• Top Mount Control
• Variable Low Pass, and High Pass for specific tuning adjustments
• Full Feature Crossover Design
• Clipping Control with Pre-Clip, Soft Clip and Full Clip Visual Indicators
• Built-in System Diagnostics
• Double Sided PCB Design
• High-density split-dome convection heat sink for high amounts of heat dissipation
• Plated RCA level inputs
• Input sensitivity:
o Low level: 0.2V-9V
• Channels 1 & 2 high-pass filter (20-45,000 Hz)
• Channels 3 & 4 high-pass filter (15-1000 Hz)
• Variable low-pass filter (40-45,000 Hz)
• Damping factor: >285
• Frequency response: 15-45,000 Hz
• CEA-2006 compliant amplifier
• Dimensions: 20-1/4"L x 9-1/8"W x 2"H
USX 2080 amp
Specs:
•anti-thump circuit
•preamp outputs
You can run one set of coils of the sub,thus only retrieving 1/2 the rms value/rating of that sub,another option, until you decide to get /swap amps and or get another sub?You can run your amplifier (4ch) in 3ch mode as well, and swap rcas from amp to amp for the rears/sub be what Id do,and run that onyx on the fron 1 and 2 ch, and bridge mode 3 and 4 on the sub , should not be an issue,Just be sure to pay attention on setting your selective switches, and turning your gains down also,and adjust during tuning/setting them.
Hcw
Hcw
BC Canada
audiobaun
