Help first 10k system
Ok so I have 2 nsv3 12s going in a 2004 Tahoe(daily driver). I am kind of struggling on what I should do exactly with electrical. Right now I have in mind a 370a alt, two runs, power and ground, of 2/0 welding cable, and 2 Crescendo Logic HPL120.
Haven't picked an amp out just yet but the TaraAmp 20k seems reasonable.
I could be way off on this so any good advice to point me more in the right direction is greatly appreciated.
Thank you
50' 2 0 Excelene Welding Cable 25 ft Red 25 ft Black USA Made 105 EPDM Jacket | eBay
Thanks.
I just found out they are sold out of the batteries i wanted. any recommendation?
Also some ppl are saying to just ground to chassis and not run full grounds from front to back. Anyone have the time to explain what I need to do?
Thanks.
Any big group 31 agm. If you have a sears or sams around you id get the die hard platinums they have a 4 year warranty that you can just walk into the store and exchange. When buying "audio" brand batteries youre just paying for the name
I'm not a huge fan of the 20k look into the newer 15k a much better daily amp. As far as the alt look into a decent dual 270 or 300a kit if you can afford it dual 370's. And batteries like posted above.
thanks for the advice everyone. is there any advice/tips/secrets you can give me about doing this big of a system? things to watch out for? any place i can research? ive looked all over for a detailed build to kind of guide me through but am having a hard time finding info.
Thanks to everyone again. your time is MUCH appreciated
https://www.youtube.com/watch?v=tx4Rnt9dGtU, 2 12s on 20k would be dope, Xs Power batts forsure,they have a faster discharge recharge rate than any cheap deep cycles, but for a daily it doesn't matter
That's the problem deep cycle. What to look for If you want a battery that can discharge a lot fast is a low esr that's why i prefer smaller batteries in larger quantities smaller batteries have a naturally lower esr.
If you plan to run 10KW into a pair of 12's you had better find a good source for recone parts and learn to build your own woofers. You will be breaking things constantly.
getloud
getloud
Jefferson City, MO
hispls
