Help DC audio 5k
shadricksimms
US
How to wire the speakers
Sent from my SAMSUNG-SM-N910A using Tapatalk
Mono block right?
Only has one channel so they just gave an extra speaker output so it would help with wiring.
Hook up your sub/subs positive to positive negative to negative depending on ohm load your wanting. Both positives are same and both negatives are the same
It's a mono amp but split internally to give the user more wiring flexability. What's the impedance of your subs?
---------- Post added at 08:41 PM ---------- Previous post was at 08:40 PM ----------
Mono block right?Only has one channel so they just gave an extra speaker output so it would help with wiring.
Without knowing impedance of subs, kinda hard to help him with wiring up his subs. Hopefullym both subs are dvc 4 ohm.
Positive to positive, negative to negative. That's it. Doesn't matter which hole as long as it's set up with positive and negative separately and on the right polarity.
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
shadricksimms
shadricksimms
US
youdoofus
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
