Craze_sniper
Master Car Audio Nooblet
I am going to be purchasing a completely new audio system for my 2000 Camaro, it has 6.5" door and sail panel speakers and 4" hatch. I was thinking about getting a 5-channel amp to power the doors and sails, and put a sub in trunk. I'm open to more suggestions than just my own, my pockets are NOT bottomless, I think i offered a comparison of a high and low priced item on each section with similar features, please tell me what's best for the price. Sorry so lengthy...
Is it possible to power the 4" with the regular HU while all 6 preamp outs are going to amp or does one shut off when the other is used?
another question, can you run 4 ohm speakers and run a 2 ohm speaker on the 5th/sub channel?
Is there somewhere to go that tells you the depth of your car speaker cavities? how will i know they will fit?
For the doors I was thinking Massive Audio RX 6 $200 per pair or Alpine SPR-60 $120 per pair
Massive Audio RX 6
Speaker Specifications
Speaker Size 6-1/2"
Design 2-way
Tweeter Design Dome
Tweeter Composition Silk
Woofer Composition Glass Fiber
Woofer Surround Butyl Rubber
Peak Power Handling 400 watts
RMS Power Handling 100 watts
Sensitivity 90 dB
Frequency Response 65 - 20,000 Hz
Impedance (Per Voice Coil) 4 ohms
Shallow Mount Installation No
Top-Mount Depth 2-15/16"
Bottom-Mount Depth 3-5/16"
Cutout Dimensions 5-3/4"
Speaker Grilles Yes
Alpine SPR-60
Speaker Size 6-1/2"
Design 2-way
Tweeter Design Dome
Woofer Composition Hybrid Layered Pulp
Woofer Surround Santoprene Rubber
Peak Power Handling 300 watts
Sensitivity 88 dB
Frequency Response 65 - 28,000 Hz
Top-Mount Depth 2-3/8"
Bottom-Mount Depth N/A
Cutout Dimensions N/A
Speaker Grilles Yes
For the sails i was thinking KICKER 10CVT65-4 $120 per pair or JL AUDIO 6W3V3-4 $210 per pair.
KICKER 10CVT65-4
Subwoofer Specifications
Subwoofer Series CompVT (CVT)
Subwoofer Size 6-1/2"
RMS Power Handling 150 watts
Voice Coil(s) Single
Frequency Response 25 - 350 Hz
Sensitivity N/A
Xmax (millimeters) N/A
Subwoofer Design Round / Circle
Main Cone Color Dark Gray
Woofer Composition SoloKön
Subwoofer Grille No
Re-Cone Kit Available No
JL AUDIO 6W3V3-4
Subwoofer Series W3v3
Frequency Response N/A
Sensitivity 80 dB
Xmax (millimeters) 9 mm
Main Cone Color Black
Woofer Composition Mineral-Filled Polypropylene
Woofer Surround Rubber
Subwoofer Grille Optional (Accessory required and sold separately)
JL Audio SGRU-6
For the amp i was thinking the Massive Audio Nx5 $300 or the Boss CE2505 $150
Is there really much difference for half the price?
Massive Audio Nx5
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 120 watts x 4 channels
RMS Power @ 2 ohms 240 watts x 4 channels
RMS Power @ 1 ohm N/A
Bridged RMS Power 480 watts x 2 channels
Peak Power Output N/A
Power Specifications - Subwoofer Channel
RMS Power @ 4 ohms 200 watts x 1 channel
RMS Power @ 2 ohms 400 watts x 1 channel
RMS Power @ 1 ohm 800 watts x 1 channel
Amplifier Specifications
Amplifier Class AB
Number of Channels 5
Total Peak Power Output 3520 watts
Total RMS Power Output 1160 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power
Speaker Level Inputs No
Preamp Outputs No
Built-in Crossover Low-pass (LP)
High-pass (HP)
High-Pass Crossover Frequency 40 - 200 Hz
Low-Pass Crossover Frequency 20 - 200 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio >89 dB
Channel Separation N/A
Bass Boost N/A
Bass/Gain Remote Optional (Accessory required and sold separately)
Fan Cooled No
Fuse Rating Not specified by manufacturer
CEA-2006 Compliant Yes
Boss CE2505
RMS Power @ 4 ohms 250 watts x 4 channels
RMS Power @ 2 ohms N/A
Bridged RMS Power N/A
RMS Power @ 4 ohms 500 watts x 1 channel
Amplifier Class AB
Total Peak Power Output 2500 watts
Total RMS Power Output N/A
THD at Rated RMS Power .01%
Speaker Level Inputs Yes
Preamp Outputs No
High-pass (HP)
High-Pass Crossover Frequency 200 Hz
Low-Pass Crossover Frequency 35 - 160 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 102 dB
Channel Separation 90 dB
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled No
Fuse Rating 30A x 3
CEA-2006 Compliant No
And for the trunk subwoofer i was thinking a Kicker CVR102 $80 in a custom built speaker box for my trunk $100 shown here
Kicker CVR102
Subwoofer Series CompVR (CVR)
Subwoofer Size 10"
Peak Power Handling 800 watts
RMS Power Handling 400 watts
Voice Coil(s) Dual
Impedance (Per Voice Coil) 2 ohms
Frequency Response 25 - 500 Hz
Sensitivity 85.5 dB
Xmax (millimeters) 12.73 mm
Main Cone Color Silver
Woofer Composition Injection Molded Polypropylene (IMPP)
Kicker 08GR10
Recommended Enclosure Specifications
Recommended Enclosure Type Ported / Vented
Sealed
Minimum Sealed Box Volume 0.8 cubic feet
Maximum Sealed Box Volume 3.0 cubic feet
Minimum Ported Box Volume 1.25 cubic feet
Maximum Ported Box Volume 1.75 cubic feet
Top-Mount Depth 5-9/16"
Cutout Diameter 9-1/4"
Shallow Mount Installation N/A
Massive Audio RX 6
Speaker Size 6-1/2"
Design 2-way
Tweeter Design Dome
Sensitivity 90 dB
Speaker Grilles Yes
Alpine SPR-60
Speaker Size 6-1/2"
Design 2-way
Tweeter Design Dome
Sensitivity 88 dB
Speaker Grilles Yes
KICKER 10CVT65-4
Sensitivity N/A
Subwoofer Grille No
JL AUDIO 6W3V3-4
Sensitivity 80 dB
JL Audio SGRU-6
Massive Audio Nx5
Amplifier Class AB
Preamp Outputs No
High-pass (HP)
Subsonic Filter N/A
Bass Boost N/A
Fan Cooled No
Boss CE2505
Amplifier Class AB
Preamp Outputs No
High-pass (HP)
Subsonic Filter N/A
Fan Cooled No
Fuse Rating 30A x 3
Kicker CVR102
Subwoofer Size 10"
Voice Coil(s) Dual
Sensitivity 85.5 dB
Kicker 08GR10
Sealed
