Hdc3 18 Custom Recone Options
i try to answer all my pm's,emails and texts. i put myself out there to be able to get ahold of easy can text me 315-530-2632 for questions or a quote. if i didnt answer ur question please let me know.
i use some of the highest grade parts on the market like nomex spiders which cost 3x of poly cotton,fyi. i try to keep my prices as low as possible! correct the more biz you do with me you will get a lil better deal but if i have the parts needed instock (which im tring to stock more all the tme but burning thru soft parts) its a 3biz day turn around.
you also get a 90day warrenty with all subs i build!
its kew understand your busy. just looking for a quote on a recone. nothing really fancy just alittle more power handling then now and also a dual 1 coil
AQ's soft parts are absolute garbage..and what's the difference between calling atomic and going through spl/psi?
there is not even a comparison between psi and atomic... dont even go there. spl audio has good soft parts and I believe he gets them from paps but I am not too sure...
no pap //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
---------- Post added at 09:56 PM ---------- Previous post was at 09:55 PM ----------
atomic sja dose have nice soft parts
stongest t joint I have ever dealt with. monster woofers and softparts.
are you looking for a drop in?8" spiders?
9.25 spiders?
also is that a small or large gap'ed motor?
i would recomend a vented basket riser too.
this is the basket/motor model i have except mine is currently a copper coil(pic is of the alum cloil): HDC318-A Aluminum Coil Subwoofer (D1_Only)
not really sure on the difference between the spiders. proly just the 8". i want it to handle about 2.5k rms
drop in or me to build?
ur talking 8layer flat wound with triple nomex stiff spiders and dual sewn leads. i have everything instock but running low on d1 8 layers but will order more //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hm not sure what its considered llol. i would be the one putting in the recone. so i guess pre built and i would drop it in. so i guess thats considered a drop in.
IMO i would go with a 4 layer edgewound coil, 2 soft spaced spiders, and direct leads... try to keep dat mmd low brah.
i think his coils a 4 layer if im not mistakin. i just want the sub to be good on 2.5k tho ima try to the 3.4k at it
bgowdy
Heroes are remembered, but legends never die
bgowdy
Campbellsville, Ky
mlstrass
