have amp and sub box already
nickm
This is going under the rear seat of a Dodge 4 door truck.
I lifted the seat 4" and made a box under there. I have 3.75 cubic feet. The box is completely sealed. But porting IS an option if needed. I listen to every thing. I mean ever thing. Classic, wrap, country, pop, Spanish, hard rock. Mostly pop country and Spanish.
My amp for the subs is a Kicker Kx1200.1. I plan on upgrading the rest of the system later. I already have (2) KICKER kx 600.4 to run ever thing else. I also have 2 1.2 caps.
I would like some 12s. But if I 10s would be better suited then I could do that also. I have looked at the kicker solo baric L7 and the Alpine SWR-1242D Type Rs and the infinity 12s (forgot what they are).
Suggestion or recommendations?
Thanks
yea are those chambers seled off from each other looks to me that your boxes are alot smaller than what your original post says
main.php
Ill see if the pics work here. In this pic you can see the bottom. I fiberglassed the "bowl" areas of the truck, to make the bottom of the box.
main.php
Sorry the pics only show up as links.
here is what you should do.....wait a month or two untill the new Kicker CVX comes out and put 2 12" CVX in there.....that would be more then enough bass......bass would be comin out of ur asssss...but seriously....do it
yes port them to 35hz...yes it shud be enough
edit:by port them to 35hz i meant port them to about 35 hz...it doesnt have to be exactly 35 hz.... but no more then 38 hz id say
Thanks a lot for your help. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif I just wanna make sure I am on the right path. Ill figure the port size when I get a little closer to that.
nickm
nickm
houston,tx
nickm
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
