Green Light on amp is on but no power to subs
srhub
Okay so I have a Kicker zx300.1 amp powering 2 Kenwood KFC W3012 subs. It worked fine then one day I turned my truck on and there was no bass coming from the subs (very little actually, kind of like a slight hum at loud volumes). The subs are fine I hooked them up to my friends car and they worked. So is it something in my wiring (which would seem strange seeing as it happened abruptly) or is it something internal in my amp? Or is it possible that the channel went out? The light on the amp is green and all the fuses on the amp are good. The amp is pretty old I think it's the 2006 model, I'm going to replace it this summer anyway but I was just seeing if I could get it to work in the mean time. Any help is appreciated
try your amp in a different vehicle, or try different speakers on it... if the problem isolates itself to your amp then its your amp, if you suspect bad wiring then re-do everything. Sounds like the amp may have issues if it worked one day and not the next or w/e...
Alright I'm gonna try seeing if it works in someone else's car but I need to find someone around me who has a system setup. My friend who's system i hooked my subs up to originally is from my hometown so I can't use his while I'm at school.
only wires that it could be if theres no sound to speakers is the rca's or the wires to the speakers, check those and if its not them then sounds like ur amp... good luck
The wire's seem good and I only checked the rca that plug into amp so far. If it's the amp is there a way to fix it (cheap) or is the new amp my best option?
check behind the radio too, probably they got loose and if those are good then its definatly the amp, maybe u burned something up inside, i dont know much about fixing them so sorry cant help there, but i would think its cheaper to get fixed then buy a new amp u just got to find someone who fixes them
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
781
I am not well versed in box design, so I do not know outcomes based on over/under sizing. The one thing I do know is that too big of a port will...
762
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
srhub
srhub
Austin, TX
srhub
    May 24, 2024
