Got a situation with an old school kicker solo baric 15
  • 2
Andbar000
I came across this 15 and it was cheap so I just bought it without hooking a multi meter to it or testing it, and Dude was willing to trade l back if need be, (i’ve made my fair share of mistakes in the past in which I have learned from and have a damn near full proof system to where I don’t **** my equipment up ) I hooked it up with a brand new amp running at two ohms 1000(750)rms, To my disappointment, I didn’t get any kind of vibration from the subwoofer unless the gain was all the way up along with my volume on the head unit, there’s only a positive and negative on the speaker and the amp is brand new, so I figured the sub was blown but it makes no kind of crunchy noise when pushed in nor does anything look bad from the outside looking in, but just to make sure I got a lanzar vibe 261, I tried bridging it to the kicker as well as just one channel,same exact issue. What could be the issue because I have a planet audio 15 running from the amp and it works fine. I’m kind of thinking it might be a lead on the subwoofer itself not getting a good connection? Because it looks like somebody tried to solder it back on the speaker but I can’t tell exactly what happened because the person I got it from got it from somebody that became deceased. Any kind of advice here? Thank you!Also the multimeter read zero, I guess I’m asking if there’s any other issue that could be fixed with it that might be simple
Hook a multi meter to it.
I came across this 15 and it was cheap so I just bought it without hooking a multi meter to it or testing it, and Dude was willing to trade l back if need be, (i’ve made my fair share of mistakes in the past in which I have learned from and have a damn near full proof system to where I don’t **** my equipment up ) I hooked it up with a brand new amp running at two ohms 1000(750)rms, To my disappointment, I didn’t get any kind of vibration from the subwoofer unless the gain was all the way up along with my volume on the head unit, there’s only a positive and negative on the speaker and the amp is brand new, so I figured the sub was blown but it makes no kind of crunchy noise when pushed in nor does anything look bad from the outside looking in, but just to make sure I got a lanzar vibe 261, I tried bridging it to the kicker as well as just one channel,same exact issue. What could be the issue because I have a planet audio 15 running from the amp and it works fine. I’m kind of thinking it might be a lead on the subwoofer itself not getting a good connection? Because it looks like somebody tried to solder it back on the speaker but I can’t tell exactly what happened because the person I got it from got it from somebody that became deceased. Update I did hook a multi meter to, zero impedance View attachment 26421View attachment 26423View attachment 26424
Andbar000
Andbar000
Michigan
marc2112
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
