Silver
Well, I got my amp tuesday from onlinecarstereo.com and everything. Shipped nicely, no dents in box nothing bad at all.
I hook it up, re-wire my sub up to 1ohm and everything and my amp plays good and all, but it goes into protect about after 45mins of play.
The amp doesn't feel hot, the sub doesn't feel hot and everything, I don't think something is right here.
For one, the amp puts out about 1300rms at one ohm. To actualy get my 15" L7 D2ohm to move (not even loud) I had to set the gain to 3/4 and my bass boost up a quarter. Its going into protect, but soon as I turn on and off my radio its fine. My H/U settings are.. Sub vol+6 bass +2 sub lpf 80hz..ect nothing was changed since I had my punch801s in it.
The amp slips into protect. I don't get it.
So I hooked up my trusty fluke to the sub coils. Each coil is @ 2ohms, the output of the amp is at 1ohm. (Bridged my 87). The amp powers up fine I replaced my power and ground wires with new stuff. It just seems like when I really get the sub moving it goes into protect.
P.S. When I had my BX1500D I only had to set the gain less than 1/4 and it was unbearable. No bass boost, nothing I wired the L7 in parallel and that is 1ohm. I even double check by using the sub wiring config here.
Do I have a faulty amp?
