Got a problem , any idea ? (**** draw inside )
Sounds like the coil on the sub may be damaged from the clipping. To set gain you play a test tone an then check for AC voltage at the speaker terminals. In your case I would rewire to 1 ohm to be sure the amp isn't clipping. The you take your desired power (700) multiples by your ohm load(1) then the square root of that number. So the square root of 700 is how many AC volts you want to see.
wire was fine , ive try to switch sub and reconnect but the same sub is getting hot, even if i switch subs connection and place in the box , i guess ill wait my ordered dmm
Again.... if the subs are identical and only one is getting hot, there's something different between them. Either they're not wired the same or one of them has issues.
h2h0e
h2h0e
canada
maylar
