google "acoustic elegance"... you will find a sub that will intrest you very much //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
i beat you to it //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifHere's another option from AE.
http://www.aespeakers.com/drivers.php?driver_id=8
My linked out reply pwns your vague reference to a search engine. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifi beat you to it //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Here is a detailed explanation: http://www.the12volt.com/caraudio/thiele.asp.707 qts
What does that mean...? In english
A few things about IB subwoofers in general. For home theater use, IB subs are mounted taking advantage of an attic space, closet, basement, garage, etc as the enclosure volume. For an IB to perform properly you ideally want the volume to be equal to a minimum of 4x the Vas of the drivers. This will make the Qtc of the system equal to the Qts of the driver. In this case, .707 is what we are looking for. The original IB15 was designed specifically for home theater infinite baffle use. They are typically sold in groups of 4 or 8. Fs is very low at 16Hz and suspension is very soft to allow them to take very efficient use of Xmax. The less power you need to move the driver to full excursion the better. With the Qts of .707 and Fs of 16Hz, your F3 point is going to be approximately equal to that 16Hz Fs, assuming you have enough volume. In a typical home theater environment with room gain added you can expect good extension down to 10Hz in room. This is the best way to get that kind of low extension.Here's another option from AE.
