Good Design?
Do you put in volume of box after displacement of the driver AND the port tubes or just with the driver. Becuz if i put in say 9 cubes with the driver..the length of porting is diff than if I put in say 8.8 cubes becuz of port displacement.
the box is 9.15 cubes counting the subs displacement but not the port displacement. Fi says 3.5-4 for each ported so i shuld be good even after port displacement
Guess i need a little less port if its 12-16 cuz 170 would be 18. 18"x6" port that goes 8.39" into the box would be 151 sq inches i think? at 35 hz.
18*6=108. Area is 2 dimensions, volume is 3. Quit thinking and guessing your numbers and just select the calculator app on your comp and plug numers in. Its not that hard.
kfx450r
kfx450r
Hammond, Louisiana
mlstrass
BP1Fanatic
BP1Fanatic
