Good battery?
Franklinnn
Ill put this cord here...
i have a 2005 neon with a 5 year old stock battery. 'nuff said. 500wrms doesnt really agree with the current charging system.
So for such a small system (and possibility of adding another 500w) an uder hood battery will be fine, but i dont know what kind to get. I have read a ton of bad on yellow tops, and need to find a good main battery.
Should i go with the Cheap walmart, fancy from walmart, . In addition to the big 3, should an 85a alt be fine?
I've never had a problem with my yellowtop...it's like 5 years old now and still going strong
I have read since they have shut down thier US plant and have gone to mexico, their new batteries are not good.
Check out the C&D Tech batteries floating around in the FS section of the classifieds. You can usually find one for around $100ish, and will be well worth it over a interstate or everstart IMO.
should i be looking for a higher CCA, or just reserve power? as a general statement, the more money, the better it will be? or are there cheap ones to look for, or expensive ones to not buy?
I think my car has the 120, i have a 2005 and the part number is 5033253AA, but cant find a good link if its the right part.
nope yours is 85amp, a pt cruiser 2.4 alt will fit or if you feel so inclined look up around a 02 durango 5.9 and there is an optional 160amp alt, you will have to swap the plug and probably the pulley but it will bolt
i know some 2005's are the 120a if made past may. what is the part number for each one, or how could i make sure thats right?
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Franklinnn
Franklinnn
SL,UT
Franklinnn
vegang
vegang
