Good 4 channel
cracker7213
16
usa
Hello, Im pretty new to all this. I have purchased some infinty 6030 2 ohm components with 75 rms and wanted to know a good amp ( ) that could power them. I have heard there is not alot of mid bass so i was thinking of getting a sub as well. I just want a semi sq system. Nothing crazy. Thank you.
I would look into the Boston amps over MB Quarts.
Yes the Infinities lack in midbass, & the tweeter is kind of bright.
But if you get some deadener & good placement you should be ok.
yes a good SQ sub will help out a bit thats if you learn how to tune
I was also thinking of doing an all infintiy system with a 475a amp and an 8 inch sub bridged. What do you think about this? I was also thinking of getting a local shop to oscope tune it.
Midbass and subs are different in their frequency range. To get more midbass you can only buy new mids because your subs should not be hitting midbass notes.
There's no need to do an all infinity system since there are probably better out there for the price as far as amps. Unless you just want to do it for cosmetic purpose then I suppose that's ok
cracker7213
cracker7213
usa
cracker7213
