going for SQ with balls - help with some things
Alpine H700. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
mind a link? it looks to be an in-dash EQ thats quite a pretty penny. i dont think im willing to pay that much for this. i can prolly get all seperate units for alot less. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Your putting a LOT of meat into a truck! Be sure to keep us updated, whatever you get. I would personally stay away from SUV's/Trucks unless I have a real need for them, but that's just my own preferance.
SIN= http://www.soundillusions.net -Jlaine runs itECA= http://www.elitecaraudio.com
both real good places to find more advanced answers than should I port or seal my sub //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
thanks!
and i just went to some dealers today, well. the 4x4's dont get NEAR the mileage i was hoping. but i did spot a dodge dakota 4x4 V8 magnum extended cab for 10 i believe.
and i need a 4x4 for the horriffic winters up here in centeral\northern new york. i need to drive quite a distance (50 miles?) to work each day, and its on a road thats not a 4 lane highway, lets say that. mostly country roads. thats why i want such a sweet system =)
ill go over there and ask about the crossovers.
where did ya go squeak!
time for me to finish my sociology essay or i fail. =p
due tormrow. 1\2way done.
for horns you need at least 24 db per octive crossover slopes, the trick to getting what most use horns for is to get as much useable freq response from them. i had an idx 24 on mine- thats major bucks new. 24 db allows you to cross them over lower 500-1000 hz than you would with a less step slope. the steeper slope allow the mid bass to play cleanly up where the horn starts. personal opinion you dont need the 6.5's. when i first read your pm i thought the 8's were your subs lol i just reread everything now. i would get the eqx from audio control. if you really want digital i have a c-90 xdp-4000x set up that hasnt been used but my price on it will be firm because i wanna use it. that would do everything only hard part is eqing it and getting it just right 10 band left right parametric eq with 250 diff combinations-just make sure ur lap top has alot of batteries as that or a reg computer with a long serieal cable will be needed. i just want a 1 amp system and there isnt a 5 channel i seen that i can say will power a mid bass well enough to keep up with a horn. my world finals car had 12.5 per horn 150 each going to idq 8's and 800 to a pr of idw 15's. eqts are nice (can be noisey) but for a simple set up at a buget level (still nice though) the eqx would be my choice (but not if money was no object) i have set 2 systems up with that peice 1 with cd-1e's (muhahahah) and another with cd-2 mini horns. (i dont like mini horns)
the version of idx 24 i had used xlr connectors they dont take regular rca's just so you know the idx 24 is a 12 volt converted yahmaha peice if i remember right ill post you a link
i sent you two pm's btw. the eqx analog version is fine ans should be had for 200 or their abouts on line. the whole theroy behind using horns is to have LESS source points so DO not use the 6.5's. if you are worried about volume 1 cd-2 by it self powered full would BE PLENTY loud (but wouldnt image worth a shit lol ) i would get a real strong 4 channel amp 4x100 rms at least put the koda 8's in the front kicks and then turn the gain WAY down on the horns channels.
req
am a mod.
req
Syracuse, NY
audiolife
