going for SQ with balls - help with some things
thanks for the link. i emailed Tru to see if there is a price for that F-2A, it looks to be an all in one solution for the problem im having. specs are below - and thats exactally what im looking for. chances are itl be like $500 or somthing.
*sigh*
High Pass @ 12dB / oct: 35Hz ~ 5.5KHz - ID COMP2 HLCD's
Band Pass (High) Pass @ 12dB / oct: 60Hz ~ 1.2KHz - 6.5 CTD CL-62's
Band Pass (Low) Pass @ 12dB / oct: 63Hz ~ 21KHz - ADIRE KODA 8" MIDBASS
Low Pass @ 24dB / oct: 35Hz ~ 290Hz - not used?
Sub-Sonic @ 12dB / oct: 7Hz ~ 128Hz - ADIRE 15" TEMPEST
but the HPF is only 12db\oct. does this matter?
DO NOT I REPEAT DO NOT run a cd-2 on a 12 db slope if you do you will have to set it up at about 1.5khz and when you listen to it or rta it you will need to eq it. 24 db or greater is needed. it will be 2 times as clean sounding at the crossover points and it will not make the koda 8 strain. i know too many people and myself expeirences that use own or have used audio control to say it would be far better to use an analog eqx than anything close to or around its price range. the more you want to jam on it the higher you should set the x over point, 800-1k you'll be fine 500 hz is for the guy who doesnt get overly aggressive in his musical tastes and volumes- plus your koda 8 is fine to 1 k .......
Now that you talked him into the 2-way setup, if the EQX can give him the points he needs, then that would be good since it has some built in equalization as well. My main thing was keeping him away from the AC's that use those stupid resistor packs.......he'd be pulling his hair out trying to set the xover points. Dials are much much easier and newb/user friendly. Does the EQX have bandpass on it though for the Koda's?? If not, then he'll have to make sure his amp's built in xover can highpass low enough for him....or maybe his deck and a built-in highpass he can use?
where did ya go squeak!
Paper, study, test, class, paper, paper, paper, drive home, eat, shit, relax = me just now getting back on = //content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif
Me going to bed and getting some sleep = //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Me going to bed next to my lady and not getting any puntang = //content.invisioncic.com/y282845/emoticons/thumbsdown.gif.d22f25895e9b40f2300c953691dacfa2.gif
ok guys, here is the amp;
http://www.epinions.com/pr-Dei_Viper_550_6_Car_Audio_Amplifier/display_~full_specs
ihttp://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950&item=5731707554&rd=1&ssPageName=WDVW
The ultimate in flexible multi-channel amp designs, the 6-channel model 550.6 is the perfect one-piece solution for 2- or 3-way component speaker systems, with or without rear fill. Or, use it to power a single-amp system with 300 watts of 4-channel power and 250 watts for subs.You can even add the Remote Sub Level Control for front-seat subwoofer output adjustment.
Dynamic Power Rating: 700 watts
S/N: > 95 dB
Freq. Range: 20-20kHz
Damping Factor: > 100
Input Sens.: 150mV to 8V
Rated Power @ 4 ohm: 50 x 4 (ch 1-4)
Rated Power @ 4 ohm: 75 x 2 (ch 1-4)
Rated Power @ 2 ohm: 75 x 4 (ch 1-4)
Rated Power @ 2 ohm: 125 x 2 (ch 5)
Crossover: var. 12dB 2-way (ch 1-4)
Crossover: var. 12dB 2-way (ch 5-6)
Bass EQ: No (ch 1-4)
Bass EQ: Yes (ch 5-6)
RCA Output: Stereo (ch1-4)
Protection: T,S,D,R (ch1-4)
Features
* High-speed MOSFET switching power supplies and complimentary bipolar outputs
* Dual power supplies for rock-solid power delivery under extreme conditions
* Thermal, DC offset, reverse polarity and short circuit protection
* Top-mounted controls easily accessed for system tuning
* Built-in high performance, variable 12 dB/octave 2-way active crossovers
* Variable 0-12 dB bass EQ function
* 6 channel input for full access to source or processor output functions
* Expandable architecture features include buffered stereo full-range RCA output jacks
* Variable built-in 2-way crossover for RCA outputs supports any system design
* Gold-plated power and speaker terminals and plugs and RCA connectors ensure maximum signal transfer
* Rugged one-piece extruded heat sink finished with injection-molded mounting feet
so what model audiocontrol would i be looking at? there are quite a few. i dotn mind playing around with the settings for a few weeks, because i know i can get them to sound great.
only weakness in anolog audiocontrol peices is making sure they have a good ground. if its a sh!ty ground it will make noise. http://www.mobileaudio.com click on internet directory (upper left yellow highlight) manufacturers (green box) then you get a huge list of manufacturers hit the globes by their name takes you to their website. here is a direct link however http://www.audiocontrol.com/MobileAudio/Products/Equalizers/EQX.html
i would get a solid 4 channel beefier the better because the eight needs roughly 100 watts at least to keep up with the horns (turn gains down on horn channels)
125w x2 @2 - ill just hook them up parallel and bridge two channels. //content.invisioncic.com/y282845/emoticons/chicken.gif.218ea7401db50d5e31a7e0b37e05e21e.gif
not a problem.
so the audiocontrolEQX should be a good one to get? do i have to get any of those 'modules' to get anything special?
if im only doing the 2way front, i just need ot bandpass the kodas 600~1000 (whatever sounds best) and highpass the horns at 600~1000 (likewise) and then lowpass the tempest (notsure)?
if thats what you guys seriously suggest, ill go for it.
That 600-1000 will be your lowpass point. You'll also need to highpass the Koda's ~60-80 or where ever.
Oh yeah....if you keep your eyes open, you can find those ID24 crossovers used for ~$250-$300 or so. Fantastic unit if you can get them for around that price. But then you would still need an EQ.
ya squeak if you want to come on out to check the stuff (for req) and i can help you with your horns i got an arse load to get rid of still
//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif Absolutely.....just let me know when you have time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
friday i have to be here they are redoing our roof other than that anytime but tuesday because ill be in hicksville doing a video system. ythose mods you need for the eqt arent that bad once you know how to use them pretty easy actually
yeah this stuff is over my head. I just thought I'd suggest looking to in a Chevy silverado 1500 or something. The gas mileage is good enough IMO. Mine's the 4.3L v6. Plus they look clean //content.invisioncic.com/y282845/emoticons/veryexcited.gif.c26a15f316d23068607f36ddacd7a7ab.gif
-I would NOT get a dodge. I own a 92 dakota, was my dad's truck till 2002...he babied it! But throughout the years, SOOOO many things have had to be replaced. Steering rack 3 times (coming up on 4), Exhaust 2 times, Radiator 2 times, Ran clutch 1 time, and various other little shit!
My eclipse 8053 had some dandy x-overs on it~! I think they went up to 18...possibly 24 db slope!
lol, what ur looking out is better...hahaha...peace
NG
req
am a mod.
req
Syracuse, NY
audiolife
