If it still happens get it swapped out for a new one.This is what I am going to do tomorrow to try and fix the problem:
1. Use new RCa's
2. RUn the head unit ground directly to the neg on the battery,
3. connect the filter from the 9887 harness.
IF that shit still makes soundes, im going to go insane. Can you guys think of anything else?
well I did but I had it routed through underneath the dash then to the stock wiring for the mids, and the wiring I had done for the tweeters. I wanted to eliminate any possible interference.You didn't have speaker wire run directly from the amp to the drivers originally? How did you have it setup originally?
