James Bang
Hand/Ear Coordination
Not exactly. The x-over points are not the start or end points. The speakers will still play content above or below the x-over points. This is where the slopes come in to play.1. Low-would be your sub set to 80hz so the highest note your sub would play is 80hz correct?2. Low mid- would be the lowest freq your mid would play which is 80hz correct?
3. High Mid- would be the highest freq your mid would play @ 3.2hz correct?
4. high would be the lowest your tweeter would play at which is 3.2hz correct?
In summary, your subs only play under 80hz, and at that crossover points your mids pick up anything from 80hz to 3.2hz and than anything higher than 3.2 your tweeter picks up and plays.
I think this makes sense.
I know that I have control of each speaker/channel through this head unit. Im still reading the manual on how I can change these settings for each driver.
Say you have your sub LP'd @ 100hz.
If you have the slope set to 12db/oct, your sub will play higher than if you had your slope at 24db/oct, because 12db/oct rolls off slower and is not as 'steep' as 24db/oct
Here's a picture example:
