Going active with the 9887
Thinking of doing the same thing KRISFNBZ is doing and switching my 9813 out.
1.) Does the 9861 run active? or would i need the H-701 for that
2.) What is the big advantage of active? Is it really that great?
3.) My system is as follows right now....
Front Stage: CDT 6.5 comps (think CLA-61's)
Front Amp: Eclipse 36401 (60wx4 @ 2ohm; 40wX4 @4ohm)
Currently bridged to 2 channels.
Sub: 2 JL Audio 10''...soon either a single 10'' JL W3 or 6 or 10'' ID
Sub Amp: Kenwood
Thanks for any help...
1) No, you do need thte h701.
2) More control over your system, easier to tailor to your sound, typically.
3) Cool.
Any advice on whether or not going active would be something worth doing, or would I need to go with a more powerful system to justify the active....
Could someone point me to a thread about Active?
Going active doesn't require more power, you could technically run less and be fine when going active. The speakers become a little more sensitive as there is no "go between" to rob power, IE the passive crossover.
ah, i got ya. Did a bit or reading and understand it a bit better. My eclipse amp has both HP/LP which i assume will not be used, but what about the bass boost option on the amp? Each set of channels has a bass boost knob, will they be set to 0 as well?
Okay so for the past 2 days I have completely dynamated my trunk, and my front 2 doors. As of right now I have at least 80 sqft of dynamat all over my car. I would say about 20 on each door, and 40 in the trunk(roughly)...
As far as the whole "blowing my speaker" thing... I realized that it was cracking in and out which couldnt be the speaker if it was blown. Turns out on my brand new set of RCA;s the conductor was not tight enough onto the connection on the back of the head unit. I used a pair of crimpers to make a solid connection and it all went away.
I still need to set my gains..but I like the way it sounds with the doors being completely sound proofed... Ill have pics later on. I probably spent total at least 3-5 hours per door making sure that shit was done right.
Now do another layer lol.
How's the active setup now? Did you get rid of all the noise?
Well I looked at it this way. Because I saw a link to one of the second skin audios rep's truck and how he deadened his doors....I pretty much copied that but with dynamat because I get beast prices on it. Too bad they were backordered on the liquid stuff..
I made sure that everything on the inner panel I would never touch again because of the fact that I would be putting dynaliner in between each hole, and putting 2 layers of dynamat over it(SOLID *** connection) so everything on the inside is done...and I also put 2 dynaxorbs behind the speaker on each door as well...
now as far as the outer-panel I still had alot of dynamat to it... but later on down the line I may just add another 10 sqft to each door, but as far as anything else these doors are pretty **** heavy for civic doors.
As far as the whole active setup... I think im going to keep it this way. I have messed around with the head unit, but I spent more time this past weekend sound proofing...I think going active is nice but unless you really have nice speakers its hard to tell the advantage.(Its like yeah I deadened my doors fully but look at what speakers im running...SLX's nothing too great with mid-bas) Its all about what I upgrade to in the future.
The noise is still there...and I have completed the big 3 under the hood completely... all with 1/0 and fused everything in the entire car as well. I cant figure out what the noise is coming from, but its got alot better and its barely even noticable now. I can only tell when the car is in idle, and the music is all the way down...so im satisfied.
Nice, and results? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Above..
BTW I will have pics of what I have done as soon as I get a chance to upload to the computer. I must have added 30-40 lbs per door... its crazy
Like I said before, I was getting similar noises when turning the gain up higher on my us amps 2 channel. I swapped out the us amps 2 channel component amp for a JL 300/4 and I no longer have the noise even with the gain pretty high. Try turning the gain down a little just too see, might be your amp.
Yeah it could be my amp.. but the noise is pretty minimal.
I just though of a question. if I had a 3 way component setup, how would I set everything up with the head unit? The 9887 only has 3 RCA's....front rear and sub?..
You would either have to loose the subwoofer, or use a passive, preferrably between the midrange and tweeter.
This HU is not 3-way active capable, only 2 way + sub. Only one that is is the DRZ 9255. And possibly the Ural CDD, but if I'm not mistaken that HU is only 2 way active + sub as well.
Okay I see.... now that I realize it going active in the front is really mainly only for front stage, because I cant even power my rear speakers through HU power now that my HU is in 'active" mode. Does this make sense?....I would have to amp the rears?
krisfnbz
krisfnbz
Frederick MD
krisfnbz
