slikrider20
- Thread Starter
- #31
Well, I ended up getting the STX-4SQ today and spent all day installing and tuning. Finally got everything back together and drove around for a solid 2 hours tweaking the settings on the PRS.
Still need to properly set the gain but my first impressions are wow, active is THE ****! I'm a guy who loves tweaking, customizing, and fiddling with stuff all the time so this definitely suits me.
Previously, I made my own MDF baffles to fit my 6.5 evils as the car came stock with 5.25's, but I stumbled upon these (https://www.amazon.com/gp/product/B007ZQGZWO/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1) on Amazon and decided to give them a shot. They worked perfectly, pushed the speaker out from the door window enough to clear that yet I was still able to get the door panel on. I also went to home depot and bought some air conditioner foam (Frost King E/O 1-1/4 in. x 1-1/4 in. x 42 in. Foam Air Conditioner Weatherstrip-AC42H - The Home Depot) to act as a fast rings replacement, as my packaged got delayed and I didn't want to wait. I just used some 3M 90 spray adhesive and it actually worked quite well. I was able to get foam around the entire speaker and between the speaker and the door panel pretty easily actually.
I was always under the assumption that when going active on this deck - highs replaced fronts, mids replaced rears, and sub stayed the same. I found that was not the case and quickly swapped my fronts and rear RCA's and problem solved.
Don't have my exact crossovers memorized but I think it's something like this:
lpf -80hz 12db
mid hpf - 80hz 24db
mid lpf - 4khz 12db
high hpf - 3khz 24db
A lot of people say the Auto EQ/TA is junk on the PRS but I tend to like it. It's worthless for the sub but I don't really care about that. It gave me a wack reading on the front left tweeter of 160inches 2 times in a row, I'm not sure what's up with that. But everything else was pretty close so I fine tuned it slightly. Left all the levels to where the PRS calculated minus sub of course. Flat EQ.
I'm sure ill be constantly tinkering with this for awhile, but all in all, I'm really happy I went this route. The quality of this amp for less than $200 impressed me as well. The 65watts per channel seems to be plenty even with the power hungry evils - but I think my next step will be upgrading to those Stereo Integrity Mids and possibly their tweets as well.
lpf -80hz 12db
mid hpf - 80hz 24db
mid lpf - 4khz 12db
