Given trunk measurements..
I ran 3 12's and recently switched it up... sold 1 and now run 2 in a much larger box. I got a notion then some advice from here and did it... this is how 2 turned out and I seem to have gained overall and make more efficient use of my power. Get a load of this... [http://i.imgur.com/BgrwbZT.jpg] ... in a Blazer not a Corolla. Think about it... you still need room to mount your equipment.
If you gaied with 2 12s it was user error.
In a trunk install as long as you have 4"s from the rear its fine.
Ive tested more than a few configurations. The box would be 6 cubes with 90in^3 of port area and it will be louder and have a flatter response. Sure you could get a larger peak around tuning with a larger box and two 12s but your going to loose ouput below and above tuning..
Typically id say go for a 18 in that sized trunk but 3 12s would work good.
Show this weekend. Shoukd beable to hit a 146.5 with 1 15 in just a basic install..
If you gaied with 2 12s it was user error. In a trunk install as long as you have 4"s from the rear its fine.
Are you for real? This thread is dead and I'm happy with my install. I'm looking to help someone but you seem to want to prove you superior knowledge with every post. It's tiresome man... I bet I can pee farther than you...
I tell ya...has an answer for everything. Whenever someone suggests something, or from a few people, he chimes in and says no this is even better.
SoundofLife
SoundofLife
Lincoln, NE
Boomin_tahoe
vegang
vegang
