Given trunk measurements..
2 12's will do well... you have enough room easily and you will have lots of space left over if you go with the recommended box... Here is a pic of 2 in a S-10 blazer 4 door with a 6" extension I put on to tune it to 28hz... http://i.imgur.com/h0lldsD.jpg ... Lots of space left over there!.. That box is 37.5 x 14 x 21 and surprised me as my build is a budget one.
2 evl 12s on rated power in a proper box will be significantly louder than what you currently have
yep 2 12's., even the ddx would be loud, i've read some killer reviews of the old model vvx saying they louder that other more expensive subs mentioned here.. but again look at the fu 750's and even ssa icons.. just settle on 2 12's with about 5-6 cf ported box and shop for those..
Funny,,,,I had 4 10's in my s10 blazer as well. it was a tight fit back there.
3 12s end of discussion. NO doubt. dual 4 ohm drivers parallel should give you .67 what amp do you have?Id slap 3 american bass TNT 12's.
Im positive that you could get 147 out of the treo.
Disregard this user. Has an answer to everything.
Yeah... IDK... I'd be wary of the box size this was a spec box in my Blazer with 3 EVL 12's... http://i.imgur.com/sizegdM.jpg ... that would be a TIGHT fit indeed in a Corolla trunk.
I'd quit trying to jam a bunch of subs and focus on a QUALITY pair in a good box with real power... 2500 is about where i'm at and that is nothing nowadays!..LOL!
I ran 3 12's and recently switched it up... sold 1 and now run 2 in a much larger box. I got a notion then some advice from here and did it... this is how 2 turned out and I seem to have gained overall and make more efficient use of my power. Get a load of this... [http://i.imgur.com/BgrwbZT.jpg] ... in a Blazer not a Corolla. Think about it... you still need room to mount your equipment.
i meant just 2 Skars!
SoundofLife
SoundofLife
Lincoln, NE
Boomin_tahoe
vegang
vegang
