getting too loud while others arent
BringTheBass
my subwoofers unevenly get louder than others. when i turn up my HU, some of the smaller subwoofers hit their max, while the larger ones still have a way to go before THEIR max. i have 8 subwoofers. do i have to take it somewhere to get it specially tuned or something? I would just get rid of them all just get two big powerful amps and subs but i just recently got new carpeting and all of the inside is covered in leather padding, and if i take out the boxes it will leave large portions of metal roof and floor showing. "the boxes were installed when i bought it.
lol....8 subs...diffrent sizes.....cancellation maybe //content.invisioncic.com/y282845/emoticons/sick.gif.b1847c8dabbfeeddbcf1a78052249e10.gif
....id just redo the hole setup...
what you prolly did is tweaked with the gains for each amp at differnt times...
THIS IS JUST A SUGGESTION IM NOT POSITIVE!
BUT I think why not try first turn your gains all the way down.... get it to one level, and then tweak ur amps at THAT volume...
correct me if this is wrong but soundes like thats it right there
^^^ definately, different subs, with different sizes and impedence. It makes for a bad situation. Find a sub you want then sell the rest.
it wouldnt be a problem with different size subs. as long as you have different amps going to each size and make. you can then tune the gains to match. now depending on the power difference and amplifier difference they might be a little off but you should be able to get them pretty close. unless something is tweaked in one of the subs or amps.
BringTheBass
BringTheBass
oregon
squeak9798
