Getting ready...Wolfram audio
We will try both ways, 1 amp per at 1 ohm each and strapped at 2 and .5(.25) each amp. I shoulda have the electrical to handle it. We have all necessary means to match gains.
I have a handy SMD 4 block terminal on the box so switching around will be easy enough.
Strapped? I would do 1 amp per sub. Unless OP has an oscilliscope, a good DMM and some know how to phase shift them perfectly.
Id wire a coil from each sub in parallel to a single amp. that way you can phase the subs properly. the amps will "fight" each other and you can easily tell when both amps are in phase. Using low power ofcourse..
Yeah that's what I was leaning towards for him to do. Going back to that barevids vid on youtube, guy there explains what/why it happens and why it doesn't always work.
Found it
Appreciate the input! I'll check out the calc site and see how it compares. I'm in the beginning stages of building the box. Unfortunately with...
750
Anything worth getting is always worth it more at a steep discount. Not familiar with that unit, but the brand is great.
I'm putting 2 under my rear seats with 2 passive radiators. Only a 3kw amp. Only reason I'm selling my adire subs before even trying them. Granted...
20
I'm stupid. Please repeat what stupid me said that was wrong.
17
dacheatham
dacheatham
Russellville, Arkansas
dacheatham
    May 12, 2024
Brendon Jenness
    May 11, 2024
