Get away with 8 gauge?
adblink182
My last setup was 1 d-class 1000 watt amp.....1 cerwin vega 12" sub.....1 4-ch Alpine amp and factory speakers.......
all of that was running on 8 gauge wire...
my new setup will be the same amp, but 3 12"s and no alpine amp
can I get away using the same wire for my amp? or do I have to use 4g?
8 ga?
Be for real and just buy a $30 kit and do things right.
It makes me cringe when people run that much power of 8 ga. the best is when people use left over speaker wire for power wire.
hmmm ok I get the point, lol.
Just wondering because the guy said I should buy some kit that was going to cost me like $50 which included rca's, 4g and whatever
but I already have 2 rca cables and really only need the 4g wire and I guess a fuse. The fuse I was using before wouldnt be good enough? i know its hard to say without knowing exactly what it is, I'll get that info later
When I upgraded to my 4g, I got it from a welding supply shop, 16 bucks for the crimp terminals and 25 feet of wire. I had enough for the main power run, ground, and I had about 4 feet left over.
The only shitty thing is that when I went to the sound place to buy the fuse holder and fuse, I ended up spending like 11 bucks or something, so I kinda lost any savings gained on the wire.
Dont let them sucker you into buying new rca's either.
well I have the fuse holder already from my last setup....but want I need to find out is if I am going to need a bigger fuse or not
if not, then all I gotta do is go out and buy 4g wire
adblink182
adblink182
Ontario
monte_carlo97
