Gain Setting Subs Connected??
Unhook them, but it won't damage them if you left them hooked up. Unless you go over the voltage your trying to get and clip them tremendously. I usually set mine with them hooked up. I don't use a DMM though, I use my ears. Unless I have way too many watts on hand.
I thought that you need the subs connected because the amp wont know the final load...which is 2 ohms for me...
As long as you do your math correct your fine. For example: Say I want set my amp(xenon 100.4 100x4@1-4ohms) up to 100@2ohm so 100x2=200 Sq Rt of that is 14.1. Then I would know it takes 14 volts to make 100 watts running at 2 ohms on any amp. Just so you know these measurements are never exact keep that in mind.
drifterman33
drifterman33
Hell (aka Guerin)
thehardknoxlife
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
