gain question
mtx11
Bump Till There Nuttin
If you set the gain according to how many ohms you have to power ratio. is it still putting out the rated power.
Example. if i have a kicker 1200.1 amp. and have the gain set to 1/2. its that 1200 watts or is it 1200 watts witht the gain on full ????
i want to know where they rate an amp at at what gain setting . full , .75 .50 .33 .25 0
Each amp will put out different numbers at different places due to the difference in voltage being fed to it from the vehicles electrical system. You need to get a DMM, so you do not clip your amplifier...
ya i under stand the clippin gbut it i have it set where its not clipping . is it going to produce 1200 at around 1/4 . or a little more
All of those.
That's what a gain is for. To allow you to achieve full power output (without clipping) over a wide range of signal input voltages.
If you have a lower voltage input from the RCA's, then you need to turn the gain up to achieve full power output. If you have a high voltage input from the RCA's, then you need to turn the gain down so that the amplifier doesn't clip, but you will still achieve full power output from the amp.
You really should read the gain setting tutorial first.
^^ Amen to that. Everyone highly recommends it bro and trust us, you will thank us after //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yo Trigger, are you busy today? I was wondering if you can check out my system real quick. it shouldnt take that long. thanks bro.
mtx11
mtx11
lehighton , pa
danteBirosel
