The RF Power T2 component set is bi-ampable. 100w rms to the midbass and 75w rms to the tweeter according to their literature. Looks like a good match for the Head Unit as I can make it 3-way active (Twt, Mid, Sub) on the RCA outputs. I will do this next.
I have noticed some panels in the car vibrating. The center dash where the head unit is mounted is rattling. I have some material here for exactly that issue. I will need to order some more sound deadening for the doors.
I can use the front channels of the Soundstream for the tweeters (-5db 1kHz tone set to 17.32v @4ohm - 75w)
I can use the rear channels of the Soundstream for the mids (-5db 1kHz tone set to 20v @4ohm - 100w)
I have the subs set on the RF 1200-1D (-10db 40hz tone set to 33.55v @1ohm - 1125w)
I know, I know... these are tones and on music it will not be these quoted wattage. However the amps wont clip, all channels will be clean with headroom. As it sits now I can listen to the stereo on Max volume 40 out of 40 for a few minutes before I tap out, bass knob a little less than 3/4 of the way up but can go full tilt with no sub distortion and the only noticeable problem is the oem tweeters. Those poor little plastic tweeters. Won't be long lol.
