Savant
Duke of DOH!
The fuses on the Vibe248 amplifiers I just got in are 2x15.. 30 amps of fuses per amplifier.. When I use the calculator I found online, it says for 1000 watts I need a 90 amp fuse in the distro block (and 4 AWG wire for amp power, but the manual says 8 AWG)..
I'm gonna go with a solid block and fuse holders inline after that, but need to have some idea what amp fuses to get..
Are the 30 amps of fuses in the amplifier different then what the amp would draw? or is it based on the efficiency so the amps only really draw 30 amperes.. seems a bit low for 1000 watts (500 x 2 at 2 ohm)....
So, for the inline fuses to the amps.. just over 30 amperes (around 40 - 50 amps maybe)? then for the 'main' fuse by the battery.. 80 - 100 instead of the calculated 225 amp fuse from the calculator? or since that run of wire is so long should that fuse be bigger.. maybe 200 amperes...
Any info would be GREAT.. as I'm trying to order stuff now //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
