A abcdefg 10+ year member CarAudio.com Veteran 2,301 0 Clarksville, Tn Jan 9, 2003 #1 i wanna reverse my sub so the magnet is facing outwards how do u reverse the polarity on a dual 2 ohm subwoofer???? thanks Click to read more...
E evo2k3 10+ year member Senior Bizznitch 1,035 0 Chicago Jan 9, 2003 #2 wire it like you would if it were not inverted, then just flip the +/- where the two wires connect to the amp.
OP A abcdefg 10+ year member CarAudio.com Veteran 2,301 0 Clarksville, Tn Jan 9, 2003 Thread Starter #3 that wont screw up the sub will it?
80_Cutlass_mn 10+ year member What needs to be here? 1,750 0 Anderson,Al Jan 9, 2003 #4 Nope sure wont
F Fender85 10+ year member Member 41 0 N. Wilkesboro, NC Jan 10, 2003 #5 They're right. You just switch the positive and negative. See, when you inverse mount a subwoofer you're putting it 180 degrees out of phase, so you must reverse the polarity to put it back into phase.
