Fuse size
That's not what I was getting at, the fusing on the 2 different runs, and btw op I would go with boomin and run 300a fusing being it's within wire range and not much smaller than what amp calls for which you probably will not pull that amount current long enough for a fuse to pop.
Sent from my SM-G935V using Tapatalk
Fuses don't safe amps!!!! They save the car from burning down.
Yes I'm aware of that. Looks like someone is coming back from a long way away from the forums much.
And if your gonna reply, make sure your spelling is good. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You think it's only about matching sub level? Man you just don't get it. You don't understand this. It's ok, I didn't at first either. I figured sound quality was about just not being loud. I had no idea what I was getting into.
I know more than you ever will. I can turn the gain up to match tge input and get 140+ then turn it down to match the rest of the car. Lol. You so dumb you dont understand what you are doing. Someone tunes your stereo for you. I can tell.
Boomin getting laughed at? Or paper maker? either way nothing new. Cuz I'm not on diyma lol
Im not tge one claming higher power input means better sq.
Ever graph you see is with 1watt or 2.83 volts. Why? Because invreased power input wont make it sound better its in theory increases output but parameter shifts occur so the more input power the more distortion. Thats the whole point of xmax.
This is basic ****. Kmsl
OMG this is ****** stupid. Another reason why forums are dying because one particular person can't shut his ******* mouth...and has to prove everybody else is dumb but him. Keep talking all this crap yet nothing to back it up...pics, builds, etc.
Way to go to derail this guys thread toiletpaper.
I supplied graphs read it. Not hard to unserstand them
You think that's all there is to it? Please god go compete. At least go listen to good cars.
You gonna get schooled and ill prove once again.
First i didnt have the sub. Then i didnt design the then its blowen and junk but its handling 3600 clipped to probably 4500 with 10% thd when i choose yet its still one of the best sounding drivers ive heard when i adjust the settings.
I need to fix the virbration in the trunk from the 150+ in the trunk..
You gonna get schooled and ill prove once again.First i didnt have the sub. Then i didnt design the then its blowen and junk but its handling 3600 clipped to probably 4500 with 10% thd when i choose yet its still one of the best sounding drivers ive heard when i adjust the settings.
I don't trust you enough to believe anything you think sounds good really sounds good.
You think output has nothing to do with it. You think all you have to do is turn it down. You think you can show up with no knowledge of sound quality and place.
You have no clue what it takes. You are on diyma, a page dedicated to a art form. You are trying to argue something you don't even understand with a full website of people that dedicate everything to sound quality.
Let's see something, what are some definitions of sound quality? What do we try to create, and explain what it is in your own words.
Output has nothing to do with resolution and distortion.
Distortion doesn't get lower as power increases its the oppsite. This is beyond retraded. I coukd give a newbee links and he would understand more than you in 2 weeks..
I don't trust you enough to believe anything you think sounds good really sounds good. You think output has nothing to do with it. You think all you have to do is turn it down. You think you can show up with no knowledge of sound quality and place.
Wtf. My definition? Its accurate reproduction. Simple as that.
psylo535
psylo535
tampa,fl.
